2.0 beta Update?
2976
7
05-27-2010 04:58 AM
AdamPfister
Has there been an update to the 2.0 beta?  I now see an "esri" logo in the bottom right corner of my app.  Also, there is a tooltip that appears when using the Draw toolbar to draw an Extent.  Something like, "Press down to start and let go to finish".
derekswingley1
I'm not seeing this yet...which url are you using for the JS API? http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.0 ?
Gregory_L___Greg_Gunther
I am noticing the same.  Also, my feature selection are not showing any longer.
KellyHutchins
Esri Notable Contributor
We released an update to v2.0 (beta) of the JavaScript API today, here are the highlights of the release:
The overview map, originally a code gallery sample, is now part of the JavaScript API. The documentation is here:
http://help.arcgis.com/EN/webapi/javascript/arcgis/help/jsapi_start.htm#jsapi/overviewmap.htm
And we have three samples showing how to work with the dijit:
http://help.arcgis.com/EN/webapi/javascript/arcgis/help/jssamples_start.htm#jssamples/map_overviewma...
http://help.arcgis.com/EN/webapi/javascript/arcgis/help/jssamples_start.htm#jssamples/layout_styledm...
We�??ve added several samples that show how to work with Image Services, view them in the Image Service folder on the JS API Samples page:
We added tooltips to the drawToolbar, these are configurable and can be turned off by setting the showTooltips constructor option to false.
We added Temporal rendering support for polyline and polygon features, we have a sample for point features.
http://help.arcgis.com/EN/webapi/javascript/arcgis/help/jssamples_start.htm#jssamples/renderer_tempo...
We added the esri logo to the maps, the logo can be turned off by setting the Map constructor option for logo to false.
KellyHutchins
Greg,
Can you provide more details about the feature selection issue you are experiencing?
Sure.  Let me clean it up a bit.  Thanks.
derekswingley1
Nice! Thanks for the heads up.
AdamPfister
Thanks for the docs, Kelly.
