Why all the entities of the layer are not displayed in the 3d scene of my web application using the ArcGIS API for JavaScript? layer of 1217 entities
2735
03-20-2023 01:45 PM
Status: Closed
DanielLeón81
I have an application that I have developed with the arcgis API for javascript. I am loading some layers that have 1217 entities and when I go to visualize them I do not see the total of the entities. I will leave some screenshots and part of the code where I load the layers.
In the first image is my designed application where you can only see some entities. In the second image you can see the layer in arcgis pro.
Part of the code:
      const aeroplane = new FeatureLayer({
        popupTemplate: {
          title: "Aeroplane",
          content: [
              type: "fields",
              fieldInfos: [
                  fieldName: "Number_of",
                  label: "Routes",
                  fieldName: "Number_o_1",
                  label: "Number of flights",
                  fieldName: "CO2_emitte",
                  label: "CO2 emitted (tons)",
                  fieldName: "Net_Spent",
                  label: "Net Spent (USD)",
          overwriteActions: false,
      scene.add(aeroplane);
      aeroplane.visible = false;
3 Comments
AndreasUlmer
The problem seems to be the layer's default elevation mode absolute-height, and the fact that all point entities have a z value (altitude) of zero.
Therefore some of the airplane icons (entities) are under ground and do not display.
There are different ways to address this, but the simplest way and what I would recommend: Set the layer's elevationMode to relative-to-ground
See
* https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-FeatureLayer.html#elevatio...
https://developers.arcgis.com/javascript/latest/sample-code/scene-elevationinfo/
DanielLeón81
Thank you very much for your response. I will try
BjornSvensson
Status changed to: Closed
Closing this "idea" as it was more of a "question" and presumably the suggestion to change the layers elevationMode fixed the issue.
