Editor Widget inserts single whitespace in non nullable text fields as default in FeatureForm
1539
6
10-23-2025 07:03 AM
Status: Open
SebastianKrings
Problem:
Lets say there is a non nullable field "name" in a feature class.
When creating new features using the EditorWiget the FeatureForm prefills these non-nullable fields with a single whitespace.
As a user I definitely expect no prefilling at all, especially no non-visible character.
The Problem is clearly: The user does not see or even recognize that whitespace and just types a name.
By this every new feature in our customers system are getting leading whitespaces in their name.
Background:
Regarding this documentation
https://pro.arcgis.com/en/pro-app/3.3/help/data/feature-classes/defining-feature-class-properties.ht...
ArcGIS adds a single whitespace in textfield values instead of null in case the field is not nullable in GeoDB.
So this may explains where the whitespace comes from, but from my point of view it is no necessary to have that whitespace set on UI side.
Plus I did not find any documentation explaining the necessarity of the behavior in the EditorWidget.
My idea is kinda obvious:
- pretend adding any whitespace in the EditorWidget UI
- add validations if all values are proper defined and give red alerts when trying to persist
Know what? The second part already exists in the EditorWidget.
I can remove the space and try to persist. An error will show me the mandatory field.
One now could argument, that this error would appear directly even the user did not yet start its inputs. And yes, I agree that is no good UI Design as well. But what if we switch the field validation to when clicking the save button instead of directly after focus lost event?
If fot any reason this not suitable, then at least any kind of hint should appear such that the user at least has any chance to even notice that there is a leading invisible whitespace.
As a Workaround we are creating an attribute rule which trims any value.
Btw: The EditorWidget in Arc JS and ExperienceBuilder as well behave the same.
Find a video attached showing the bahavior.
(view in My Videos)
6 Comments
BrantSollis2
I'm also struggling with this behavior, but through the ArcGIS Online Experience builder UI.
My users are typing into the field without realizing that the whitespace exists. In the case of ID numbers, this is causing lots of issues down the line when IDs that should match have extra whitespace.
Surely this isn't intended behavior?  I can't really see any benefit from the added whitespace other than creating dirty data.
d_dav
This is causing issues for my organization as well.
BrantSollis2
Update:  I was able to work around this issue for my use case by editing the Feature Template in the web map.
When editing the feasture template via web map viewer, I realized that the whitespace is there for certain fields.  I just deleted the space in the template and saved.   Now when creating new features, it starts and an empty string and there are no more leading spaces!
I don't think its the correct fix, but hopefully this workaround helps you guys in the short term.  @d_dav @SebastianKrings
SebastianKrings
We cannot do this in AGE 1.3 but we can on version 11.4
Thanks for sharing.
My previous statement was wrong, it does not work as Yannick stated below.
Yannick-Atos
@BrantSollis2 We cannot edit the feature template via the Web Map Viewer. Our data is stored in an Enterprise Geodatabase, so the template is defined at the feature service level and originates from ArcGIS Pro.
The ArcGIS Pro template itself does not contain a whitespace:
The whitespace only appears in the Map Viewer template configuration, but there it cannot be removed or saved:
BrantSollis2
@Yannick-Atos Unfortunately, I'm not as familiar with Enterprise as I used to be..  What version are you on?
On older versions, you may have the option to use Map Viewer Classic to edit the templates.  It looks like versions 11.5 and up can use the Map Viewer to edit the templates, but I'm not positive.
Either way, I still believe it is something Esri needs to fix on the backend.  I don't see a good reason for it inserting whitespaces on its own.
