Editor field issue with esriFieldTypeSmallInteger and codedValues
1150
03-23-2023 02:59 AM
Status: Open
JB19
Hello everyone,
I would like to suggest an improvement to the Editor.
In this post (link), I explain that I found an strange behaviour on some fields (esriFieldTypeSmallInteger with codedValues).
The issue is that you cannot search values by name in the calcite-combobox search input.
It seems that because the field is of type esriFieldTypeSmallInteger, the search input is limited to number, even though the field has codedValues.
I can understand this limitation for a normal field, but for a field with codedValues, which appears as a calcite-combobox, this limitation makes no sense.
The user should be able to search a value by its name.
