When using the IntegratedMesh3DTilesLayer add an option depth test against terrain (like in Cesium), to hide 3D Tiles objects that are occluded by the terrain.
https://cesium.com/learn/cesiumjs/ref-doc/Globe.html#depthTestAgainstTerrain
CesiumJS sample with depthtestagainstterrain = true (https://bertt.github.io/esri_issues/depth_test_against_terrain/index_cesium.html)
Esri Javascript SDK 4.29 draws all the 3D Tiles objects (https://bertt.github.io/esri_issues/depth_test_against_terrain/index_esri.html
@berttemme thanks for submitting this idea. This is expected behavior as the data is a 3D object being rendered as an integrated mesh. Integrated mesh layers either represent the ground surface or supersede the ground surface when being rendered. I'm going to change this to In product plan as the team is currently working on adding support for the 3D Object 3D Tiles layer and once that is implemented you will achieve the behavior you are looking for. This is planned for the near term and I will circle back and provide updates as I have them.
thanks,
Andrew
@berttemme Unfortunately not yet. They had some other higher priority items come up so for the time being this is only supported in ArcGIS Pro and ArcGIS Maps SDK clients.
thanks,
Andrew
