Work Flow for Configuring Commenting in Reporter Instant App
3605
13
12-16-2024 08:37 AM
MelanieNeedle
Hello: What is the work flow for configuring commenting abilities using a related table in the Instant App Reporter? The app does not recognize the related table/relationship class I created.
SubaKrishnan
Hi @ChristopherPollard Once you click on it, it will take you into the popup where you can add like or dislike. Could you check if you have configured a numeric field for like and dislike parameters for that layer. If you still have issues, please share your app I can take a look at it.
ChristopherPollard
Thanks and yes I have a integer field for capturing likes. Here is a link to the DRAFT App
As well as setting I have for the hosted feature layer, Web Map Form, and App configuration.
ChristopherPollard
@SubaKrishnanHere are some screenshots and more info. Thanks
SubaKrishnan
Hi @ChristopherPollard are you referring to the info and screenshot from MelanieNeedle? She is referring to commenting not like/dislike. Like and dislike is a numeric filed from your feature layer.  If you give access to your layer or map, I can try it at my end.
