White text on white background of share widget in Sidebar Instant App
100
2 weeks ago
FourCornersMapping
When the share widget is opened, the window has white text on white background, making it impossible to read the text.
I'm using the "Light" Theme setting.
The other widgets appear normal, with black text on white background.
SarahMcDonald_Esri
Hi @FourCornersMapping
Thanks for reaching out about this. What template are you seeing this in? Is this app in ArcGIS Online or ArcGIS Enterprise?
Thanks again!
Sarah
FourCornersMapping
The Sidebar Instant App. ArcGIS Online.
SarahMcDonald_Esri
Thanks for the follow up information. I was able to reproduce the behavior you are seeing and the team will look into the issue.
I did see that the issue only happens when the header is turned off. If the header is on in the app the text looks correct. Also, if you choose to use dark mode, the text shows up as expected when the header is off.
Thanks for bringing this up.
Sarah
