Table view with attachments
1004
12-10-2023 12:52 AM
OriLahav
Hello,
Looking for an easy way to share survey123 results as table only (no map or geo data).
Similar to "Data" tab in ArcGIS Survey123 web.
I do not want or need to show map.
The regular attachment viewer (attachment focused) still show map. Also, the attachments show in one gallery. I have over 10 fields for each have an attached pdf or image.
I want to have table as main view and by clicking a row the user can see the fields and images per field.
(similar to "Data" tab in Survey123 web)
Any ideas? maybe different type of esri app.
Thanks !
gargarcia
I think you could do an Experience Builder with just a table widget and an image widget. Or the details widget probably if you make the layer popup just the attachments. You can link the image to the table layers attachments. Then you can make the image only show up for the selected feature from the table. You might be able to do the same with a dashboard.
