Slide in Instant app is not showing in right location
1202
02-29-2024 09:51 AM
Aymen_Farhat
The Instant app slide isn't displaying in the correct location; regardless of the configured position, it consistently appears at the bottom of the map. This problem is specific to the portal, as the app functions properly on ArcGIS Online.
JShi_EsriStaff
Hello Aymen,
Thanks for sharing with us your Sidebar issue in Enterprise environment. This issue is a known issue and have been fixed in the upcoming ArcGIS Enterprise 11.3. Here is the defect info: BUG-000163830 for your reference.
Regards,
Julia
DavidColey
MVP Frequent Contributor
Hello @JShi_EsriStaff - have you following or have seen this post:
https://community.esri.com/t5/arcgis-enterprise-questions/11-2-upgrade-instant-apps-config-won-t-com...
I ask simply because we have a failure somewhere in our upgrade from 11.1 to 11.2, and apparently not everything installed because I can't even launch the InstantGallery page.  . . the TS can't find other js and node modules...  I'm working with support but if you have anything you could add my support case number is
Esri Case #03592799 - 11.2 Instant Apps configuration page will not display
Thanks-
David Coley
Sarasota County GIS
Tags (3)
DavidColey
Hooray!  The sidebar is back in place and functioning correctly at 11.3 @JShi_EsriStaff !  Thanks to you too @KellyHutchins !
Thanks-
David Coley
Sarasota County GIS
