There is a new button that has appeared on all my Sidebar Instant Apps, where clicking on it enabled the "Edit" widget on the sidebar. The widget shows up even with maps with layers disabled. While it honors view layer settings, this is problematic for our public applications. Can this be resolved?
Thanks, @KellyHutchins! Is that under Theme & Layout -> Theme? I added that line to the CSS section but the "TESTING" button still shows.
Ok I just tested again and I think this should work.
button.esri-component{display:none;}
That worked, but I'm still wondering how a test like that was deployed on production servers that affect all your customers' apps. What's going on at ESRI that the recent ArcGIS Online update was full of bugs, and now this?
For anyone who added the workaround you can remove it now the issue is resolved on arcgis.com. You can also leave the workaround in place if you'd rather not configure the app again it won't affect anything.
Editing widget its not working as well, you draw a polygon and after you click create nothing happens. will the issues are related ? will it be fixed with tonight updates?
I just ran a test with an editing app and was able to successfully add polygon features. This is probably a different issue. Can you provide more details? Or if you app is public share the url with me?
