Map Pin doesn't drop where clicked - Zone Lookup - Causing error in results
1077
01-26-2024 12:11 PM
PrestigePreparatory
Anyone else encountering this issue?
Map pin is not dropping where the user clicks, thus causing an error in results for Zone Lookup
In the image below, I clicked where the red dot it, but it landed in the road (green pin)
clicked the red dot -- map pin landed on streetclicked the red dot -- map pin landed on street
KellyHutchins
Esri Notable Contributor
It will use the geocoded address so that is most likely the street centerline in your example. Do you have a public app I can use to test?
