Location widget in 3D viewer
2020
03-25-2022 06:18 AM
NicolasGIS
Honored Contributor
Hello,
Did I miss it or there no way to add a "Location" widget to the "3D Viewer" app ?
https://www.arcgis.com/home/item.html?id=888910da7fdc4b11ac32825ad2d87816
Would be nice to have it if it's not there yet !
Thanks for listening !
Nicolas
Tags (3)
SarahMcDonald_
@NicolasGIS
Ah I see, makes sense as to why you weren't seeing that tool. Yes, the current location button was new as of the December 2021 release of ArcGIS Online. So hopefully that should be in the next Enterprise update.
Thanks!
Sarah
SarahMcDonald_
Hi @NicolasGIS
There is a "Find current location button" that can be included in 3D Viewer apps. In the configuration of the app you can use the search for settings to search for "location".
Or if you toggle off Express setup so you can see all the settings, that is located in the Interactivity section -> Explore/navigate -> Find current location.
Hope this helps!
Thanks!
Sarah 
NicolasGIS
Honored Contributor
Thanks for your reply @SarahMcDonald_ .
I am on ArcGIS Enterprise 10.9.1 and this functionality seems to be missing:
Capture d’écran 2022-03-26 à 15.20.44.pngCapture d’écran 2022-03-26 à 15.20.44.png
I guess it's a new feature of latest AGOL release ?
Coming to enterprise next version then !
Nicolas
SarahMcDonald_
@NicolasGIS
Thanks!
Sarah
