Is the Compare App for ArcGIS online working properly?
676
07-02-2019 12:34 PM
SD61Boundaries
I have been using the Compare App Template on ArcGIS Online for the last year without issue. Now when I create a web application with this template the data does not load correctly. The same maps load normally in all other web template applications I have tried.
Is it possible a new version of the Compare template has been released that has a bug? #compare app
April 2019 - Both maps in Compare app displayed correctly:
April 2019 Comparison App Template
June 2019 - Both maps in Compare app display only points, text and polygon outlines but will not display polygon colours.
June 2019 Comparison App Template
Tags (1)
SarahMcDonald_Esri
Can you provide the link to the application? As a test, if you try to build another compare app from the web map do the symbols and labels appear?
Thanks!
Sarah
