Instant App Sidebar - Info Panel does not open properly on smaller resolution
816
02-27-2023 12:08 PM
NTurpin
If you are using the Sidebar app on mobile, tablet or even on your PC if you reduce the window size, the Info Panel will not open properly.
As you can see on the images below (in french), I select a feature and the Info panel icon is highlighted but it won't open. To open it (as seen on the second image), you have to click on another tab and click back on the info panel to see the content.
I've tested it on multiples different devices and browsers and I always get the same result.
 Thanks
KellyHutchins
Esri Frequent Contributor
I can't repro this one using the sample app here: https://www.arcgis.com/apps/instant/sidebar/index.html
Is your app public? If so can you share the link?
NTurpin
Thanks for your fast reply,
Yes my app is public you can try it: https://repentigny.maps.arcgis.com/apps/instant/sidebar/index.html?appid=a9efa287ad454981a57f1dcf9a9...
I've also tried your app and it works great on my phone, but I get the same bug on Chrome or Edge if I reduce the window size.
JiříKomínek
New Contributor III
I have the same problem. Any solution now? it should be reported as a bug.
KellyHutchins
I cannot reproduce the issue with this sample app: https://www.arcgis.com/apps/instant/sidebar/index.html
Are you able to repro with the above link? If so can you provide steps?
