Instant App Layer Options Field Visibility Showing All fields in edit view when only some are checked.
696
12-03-2025 06:29 AM
CamTurney_CityofCF
I have a Manager instant app that is used for editing a layer. I have a configured pop up for the initial selection. Then when "edit" is clicked, it is supposed to only show the fields that I have checked in the Layer Visibility section of Modify. However, it shows all of them still.
I have an identical manager instant app but for a different map. It works as it should. I am not sure why this one won't. Below are screenshots of my selection.
Any help is appreciated.
EmilyGeo
Hi @CamTurney_CityofCF
The layer visibility you configured does not affect the form. You can choose which fields to display in the form, in what order, & more when you author the form in Map Viewer or Field Maps Designer. If you haven't done that, a list of all the editable fields is displayed by default.
EmilyGeo
