Imagery viewer help
1715
08-02-2022 08:32 PM
Leigh_Brooks
I created a web map, then instant app web app using the imagery viewer. I added the app to my hub site. However, if I'm logged out I can't see the map on the hub. When I went back into the app there is an error message, "This application requires at least one imagery or imagery tiled layer to function." I don't understand this because the map uses the hybrid basemap. What do I need to do so that the map shows on the hub site? Please don't make it too technical, thank you!
KellyHutchins
Esri Notable Contributor
The Imagery Viewer app is designed to allow you to explore imagery data using various tools. You'll find more info here on the data requirements for that app:
https://doc.arcgis.com/en/instant-apps/latest/create-apps/imagery-viewer.htm
What types of things do you need the app to do? If you just want to show a map you can use the Media or Basic instant apps to do that and both have the option to enable additional tools like Legend, Scalebar etc.
KellyHutchins
Leigh_Brooks
Kelly, thank you so much. I just want to show a map with legend and basemap toggles. I will try the basic instant app.
