How to host configurable app on your sever?
2578
12-09-2020 11:02 AM
BrittaneyHarkness
Hi, I'm trying to configure the Nearby app to test on my local server and eventually my development web server but when I update the portal url, appid, and oauthappid I get an error :
(index):236 Uncaught TypeError: Cannot read property 'trim' of undefined
at Object.x [as normalize] ((index):236)
at d.e._sanitizeUrl (IdentityManager.js:36)
at d.e.findOAuthInfo (IdentityManager.js:13)
at IdentityManager.js:10
at Array.filter (<anonymous>)
at d.e.registerOAuthInfos (IdentityManager.js:10)
at ApplicationBase._registerOauthInfos (ApplicationBase.ts:647)
at ApplicationBase.load (ApplicationBase.ts:202)
at init.ts:39
at wa ((index):19)
Any thoughts?
2 Solutions
by Anonymous User
Not applicable
Hi Brittaney,
If you haven't done so already try setting these values in the application.json:
  appid: <insert app id here>, // This can be an empty string if there is no app id i.e. ""
  portalUrl: <insert portal url where your content is hosted>,
  oauthappid: ""
Then, in the applicationBase.json, try setting isEsri to false.
This should get rid of the error in the console and load the app. Please let use know if you run into any more issues.
Ryan
RyanLibed
Hi Brittaney,
  oauthappid: ""
Ryan
by Anonymous User
Not applicable
Hi Brittaney,
  oauthappid: ""
Ryan
BrittaneyHarkness
Ryan, thanks!! that did the trick
RyanLibed
Hi Brittaney,
  oauthappid: ""
Ryan
