Does the "Hint" functionality for the Finder app work?
1419
09-10-2014 01:23 PM
JuneAcosta
I downloaded the latest Finder app to host on our onsite server. I can't get the Hint functionality for the search tool to work. Does this only work when the template is hosted on AGOL?
AllisonMuise
Hi June,
Hint works regardless of the environment in which you've chosen to deploy Finder. I just tested with an implementation of Finder on my web server and when I change the value of searchBox.hint the grey italicized text in the search text box changes to match.
Is this the hint you are referring to? If not, can you describe the change you are trying to make, the behavior you are expecting, and what you are seeing instead?
Allison
AllisonMuise
Hi June,
Allison
