Bugs with "Accordion panel" setting on the sidebar app
623
6
05-21-2025 11:08 PM
BrandonGuo
On the sidebar instant app, if the "Accordion panel" was turned on, the pop up panel will not follow map pop up settings, like the title of the popup. Also, for a map will multiple related tables, if the user click the details of the related record, then go back, only the current related records will show up, all others will disappear. Works ok when the "Accordion panel" was off.
Accordion panel on:
Accordion panel off:
KellyHutchins
Esri Notable Contributor
The title of the popup should still display in either mode.  I'm also not able to reproduce the second issue you mention about when the accordion panel is off where features disappear?
I'm using this test app with a custom URL param that allows me to easily toggle between regular mode and accordion mode.  Are you able to reproduce with this demo app?
Accordion Mode OFF:
https://www.arcgis.com/apps/instant/sidebar/index.html?appid=b2b0b5bc5a8446daa00505addcccdc56&classi...
Accordion Mode ON:
BrandonGuo
Hi, @KellyHutchins Thanks for the DEMO app, I can reproduce the second issue on Edge Version 137.0.3296.83 (Official build) (64-bit).
If I select a county on this demo, it will show both Golf courses and school results. Then click any of the related record details and go back.
The info panel now only shows "Golf courses result" or "Schools" result, depending on which one user clicks before.
Before checking details;
Check any school detail and go back, the info panel now only shows related schools, golf course disappeared.
Regards to the first issue, the demo app does not have overlapping features with related tables, I am guessing the bug only appear when there are overlapping features.
KellyHutchins
Ok I see the issues with related records disappearing. This will be fixed in the next release of ArcGIS Online. For the overlapping features issue I'll see if I can find data to test it out.
KellyHutchins
I'm struggling to repro the other issue. Is your web map publicly available? If so can you share the map id?
BrandonGuo
@KellyHutchins No, the map is not publicly visible. I just created two demo apps.
In this demo
If I click on the polygon and check the related pop up, it's showing the map title correctly.
In this DEMO
The pop-up title isn’t displaying correctly when the accordion setting is enabled.
Both app is using the same map, here's the map ID: 35087efe8c264d55bbdc35732687c659
KellyHutchins
Thanks the sample apps helped and I was able to reproduce and we will work on a fix.
