Broke Crowdsource Reporter after deleting field in Hosted Feature Layer
818
12-05-2018 02:22 PM
SkyeSwoboda-Colberg1
I had a correctly configured Crowdsource Reporter on my ArcGIS Online account that was working properly. I decided I wanted to delete a field in my Hosted Feature Layer and I was no longer able to submit reports. When I clicked the Submit a Report button the loading icon will spin forever. After an hour of changing the settings of my hosted feature layer, web map and Crowdsource Reporter Application, I was able to get the application working again. Unfortunately I am not sure how I fixed it, and needed to delete a second field from my hosted feature layer. Now I am running into the same issue again.
Can anyone explain what is going on or what exactly fixes this issue? It's similar to the problem described in this thread:
, except I am not receiving an error message. The program just becomes unresponsive, I let it spin like this for 30 minutes but never got an error message.
Thanks, Skye
Tags (1)
by Anonymous User
Not applicable
Posting this in case other folk come across the same/similar issue as I had a hard time finding solutions specific to this issue.
I had a same issue yesterday but from a similar action. I added a new field (date/time) to track submissions. As a result the button to start a report would initiate an endless loading session. It would not show the report form or any change other than the default loading symbol in the middle of the screen. I cannot speak for the potential solution of the original poster, but I found my solution with the following:
I set the App to organize entries by Date/Time, however the field housing the information was not "visible." I changed it in View Definition, ESRI has an easy to follow explanation of view definitions.
Then I went to Configure Pop-up to ensure/change the list of fields visible and include Date/Time. Lastly under the list of visible fields I clicked on Configure Attributes and  the check boxes for Date/Time under visible was off, and edit was on. The opposite of what was needed. I changed the attribute for Date/Time Field to be visible and not editable.
I am not sure the exact solution, likely a combination of the above, but the Crowdsource Reporter is accepting new reports.
Best of luck all!
-Danny
