Introducing the Web Editor (beta) Template
1417
10
06-26-2025 08:35 AM
SarahMcDonald_Esri
We’re excited to introduce the Web Editor (Beta) Instant Apps template — a powerful tool designed to simplify and streamline data editing workflows for both GIS professionals and non-GIS users alike.
With this template, you can create a tailored version of the Web Editor application, enabling focused, efficient editing experiences. Whether you're managing spatial data or supporting field teams, the Web Editor helps you configure the right tools for the job.
Getting Started
To use the Web Editor template, you’ll need a web map that includes at least one editable feature layer. You can access the template from the Instant Apps home page or directly within the Web Editor interface. Please consider joining the Early adopter community to provide feedback on the Web Editor template.
Configuration Options
The Web Editor template offers a wide range of customizable settings, grouped into intuitive categories:
App Details - Introduce your app and guide users with:
  • Header and Title
  • Introduction Window
Editing Tools - Fine-tune the editing experience by selecting which tools are available:
  • Feature Editing
    • Edit vertices, split, merge, move, reshape
    • Copy/paste features
    • Undo/redo
    • Create or delete features
  • Selection Tools
    • Choose selectable layers
    • Select by attributes
  • Snapping Tools
    • Define snapping layers
    • Enable snapping to grid
    • Show tooltips
Map Interactions - Enhance map navigation with:
  • Home button
  • Zoom controls
  • Search functionality
Side Panel - Empower users with tools in the sidebar:
  • Layer Tools
    • Layer list, tables, basemap switcher, legend, bookmarks, shortcuts
  • App Defaults
    • Directional pad, map rotation, default units, delete confirmation prompt
Theme & Layout - Customize the look and feel:
  • Light or dark mode
  • Preset themes
  • App logo
Tailor to Your Workflow
With these flexible configuration options, the Web Editor template can be adapted to support a wide range of editing workflows — from simple data updates to complex spatial edits.
10 Comments
ShareUser
Esri Community Manager
Just out of curiosity, what is the overall direction for esri regarding web editing capabilities? For as long as I can remember, web editing started out:
  1. The classic web map, Geoform, and a couple of others which I can vaguely remember.
  2.  Web App Builder, when it came out, has( or had) the editing widget which made it easier to configure editing using a simple web app like UI
  3. Map Viewer replaced by the classic web map by which Web App Builder had support and enabled editing
  4. Experience Builder is replacing Web App Builder and allows for web editing using a similar UI to Web App Builder.
  5. Floor Plan Editor for Enterprise Portal (11.2 - Current) also enables web editing.
So I just a few questions.
Is the purpose of this new web app designed to be a friendlier UI in terms of editing in the web, and what would the potential road map look like considering it could potentially replace several other web maps that also have editing capabilities?
Will arcade be supported by this new web app or will that capability exist only in field maps or as attribute rules?
ShareUser
Hi RPGIS,
I'll try and answer your questions, using some of the text from a similar conversation on a different thread.
First off, much time and thought goes into whether to augment existing applications or create a new application (Web Editor, in this case).  In the end we decided a separate application was best and i'll give you two main reasons:
  1. Creating a focused app - by creating an application just for editing it gives us the ability to streamline workflows for that purpose.  If you create a single app to do everything, then you have to genericize some process as a result.  An example would be the toolbars across the top of Web Editor which are context based knowing the user is editing.
  2. Configuration - In a future release (out in beta in the June Online release) we will support configuration of  Web Editor to further support streamlining workflows.  For instance, you could configure Web Editor to support only updating attributes and save that as an instance of the application.  If the editing capabilities are rolled into Map Viewer, then the options for configuration are reduced if not eliminated.
Hope that helps.  Also worth noting much of the functionality of Web Editor will make its way into web components that will be available in Experience Builder and Map Viewer at the discretion of those teams and in the context of those applications (i.e., does it make sense for the application and its purpose).
As for the road map of Web Editor, we will continue to add new functionality based on user feedback and needs.  In addition to the configuration capabilities mentioned above, we plan to support things like true curves, annotation, dimensions, parcel fabrics, topology, reconcile and posting of versions, etc.  These things will obviously take time to add, but the overall direction for Web Editor is to make it a full function editing application on the web.
Arcade can already be used within Web Editor when part of attribute rules and other capabilities (symbology, for example).  We also plan to look into using Arcade as a way to extend the app itself.  Did you have something in mind when asking about Arcade in Web Editor?
Thanks, larry
ShariF
I just created my first Web Editor Instant App to replace an old app  our engineers have used that was originally built in Web App Builder. I do find this instant app to be user friendly to configure and I love that one can batch edit attributes easily and split and merge. I think I read "explode", like explode multipart features, is on the road map which would be great. If I can add my two cents, I'd also like to have the ability to filter (Query) the editable layer.
Thank you and I appreciate this new product.
CraigGillgrass
thanks for the feedback @ShariF glad its working for you!
Yes, both of those capabilities are on the road map, with the ability to filter (Query) the editable layer closing to being assigned to a release.
ShariF
One more question. Will there be anything like the trace tool that exists in Pro under Reshape Tools? Or is there an existing tool under "Create" that will trace our underlying data? We are currently contributing to the Community Base Maps for Live Feeds for road closures and it would be helpful to be able to trace the underlying road network. In the meantime, we are using the snap functionality with our road network to draw in the road closures.
Thanks!
CraigGillgrass
@ShariF yes, that is on our roadmap but, I don't have a timeline for it's release.  But it is high priority.
ShariF
I am supposed to be demoing this app today for our engineers that I've been working on for weeks. We use an editable secured feature service. I'm trying to update attributes and randomly it works and other times I get the generic error: "Editing failed."
When I go edit in the underlying web map it works just fine.
I've cleared my cache in Google, I've tried a new browser (fire fox), I've upped the number of dedicated instances on the REST service, and I've stopped and started the service. Sill having issues.
Any ideas?
CraigGillgrass
@ShariF
Are you able to use the Developer Tools in Chrome to capture the error message when it fails?  Click the three vertical dots in the upper right and choose More Tools > Developer tools.  This will open a window to record the network calls from Web Editor.
This link provides the steps to download a HAR file:
https://support.google.com/admanager/answer/10358597?hl=en
If you can create one, that might help me to investigate why the error is appearing.
Craig
LindseyStone
Anything else on the roadmap for more interaction with the map?  Like the measure tool?
CraigGillgrass
yes @LindseyStone the measure tool is on our roadmap.
Contributors
About the Author
Product Engineer
