Unable to Add data from Excel or CSV - Insights for ArcGIS 2.0
1532
09-19-2017 09:26 PM
Muhamad_RamdhaniFajri
Hi All, I get error message when I'm trying to add data from excel or csv to Insights.
The message just says "someting when wrong".
I used to work with previous version Insights and it was just fine.
Does anyone have the same problem?
many thanks
Tags (3)
AravindStoryMaps
Hello Muhamad,
Can you verify if you can add a CSV file into Portal My Content page using the Add Item menu? View My Content—Portal for ArcGIS | ArcGIS Enterprise
I want to confirm that you can publish a CSV as a hosted feature layer in Portal for ArcGIS in order to confirm that the Base ArcGIS Enterprise deployment is sound and working.
Aravind
