Create a report with multiple pages
1075
08-22-2024 07:42 AM
AJ_devaccount
Is it possible to publish an AGOL report with multiple pages? Like this one:  Example from gallery. I have multiple pages in my work book that I've designed, but when I publish, only one page shows up in the report. I'm new to Insights, so not sure if I'm missing a step?
Tags (1)
Ian_Muehlenhaus
Great question! The trick is to "SHARE" the entire workbook. From Insights, go to the homepage of your workbook. There should be a SHARE button or something like that underneath it. Select it. When you share the workbook, people CANNOT edit it, but the entire workbook project is shared and can be perused by those with permissions: e.g., set to PRIVATE (no sharing, by default, I believe), ORGANIZATION (those in your org), ORG GROUPS (specific groups in your org), or ... PUBLIC (anyone with the URL).
Sorry my memory is a bit foggy on the tool tips and I don't have ArcGIS Insights up at the moment, but this should fix the issue. Hope it helps! (Or someone else comes with more detailed instructions.)
Thanks for using ArcGIS Insights. 👍
Ian Muehlenhaus
Location Analytics
Ian_Muehlenhaus
Ian Muehlenhaus
Location Analytics
AJ_devaccount
Thanks! That makes sense
