Can't Access Insights "you don't have permission to access Insights for Arc GIS"
7810
19
10-29-2017 06:13 AM
ahmed_hussiney
Hi I have installed #insights, then imported a valid entitlement, and I am logged in as a level 2 user, but when I try to open Insights it show invalid redirect URL and after some researchers in GeoNet I found a solution for invalid redirect URL issue by settings app redirect URLs for both http and https , but then It keep show me "you don't have permission to access Insights for Arc GIS" although I am logged in with user who is admin and level 2 with permission for insights license, any recommendataion how to fix this ??
You don
My user permission
ahmed_hussiney
Hi All,
I had fixed this issue by specifying both the http and https redirect URLs of insights app check the following post for more details
Invalid redirect_uri Error: 400
Another thing I need to highlight that some problems that we faced was show only on Internet Explorer so I recommend when you test your environment use either chrome or Firefox.
Please let me know if this fix work with you too.
ammaralotoom1
Hi All ,
I reinstall the web adapter for portal and that solved the issue on my site.
Thanks all, and have a nice day
Sent from my iPhone
CraigCleveland
Hey Ahmed,
Thanks for your reply.  When you say you specified the redirect URLs of the Insights app, can I ask you for a specific example of how that URL looked?  When I follow the link to the Invalid redirect_uri it similarly mentions the URL to Portal, and what I'm trying to confirm is exactly the format.  I ask because I have Insights working without issue on one particular Portal and all that's listed in getAppInfo is "https://[FQDN]" (in addition a few .esri.com's and .arcgis.com's, which I believe are irrelevant).  What I'd like to confirm with you and Aravind is whether you're saying to add more to the URL than that?  e.g. "https://[FQDN]/web adaptor" or "https://[FQDN]/web adaptor/apps/insights/index.html"
Thanks!
Craig
AravindStoryMaps
Hey Craig,
Let me connect with you offline so i can take a deeper look at your environment to see where we might be running into an issue. For anyone else who are still running into this issue, please feel free to comment here so i can respond!
Aravind
ahmed_hussiney
Hi Craig,
Sorry for the late response, In my case I set the redirect URLs to referee to both the external and internal FQDN, and in order to do that you should have two redirect URLs records when you search for insight in getAppinfo page.
The two redirect URL should be as following "https://[FQDN]/"  and  "https://[InternalFQDN]" [which is the internal machine name of the server]. I believe that the Internal was already there so the problem was raised cause the external redirect URL wasn't exist in insights app configured redirect URLs.
CraigCleveland
Thanks Ahmed.  I added both variations in trying to make this work...no luck.
PanagiotisPapadopoulos
check the windows clock on the machine hosting the Portal. If the time or date is wrong ArcGIS Insights or ArcGIS Pro license stop working.
There is a technical article about that (Error: timestamp invalid ), talking about the ArcGIS Pro license, but if you have wrong date follow the same steps for insight.
CraigCleveland
All are in sync...
MichaelSchoelen
So we are having this same issue, but only in Google Chrome. It works properly in IE.
I took a look at the getAppInfo page in the portaladmn, and we do not have an http element specified--however, our portal has been configured to only use https.
Anything else I can check?
CraigCleveland
Hi Michael,
We never found the smoking gun with this where I was having the issue.  It eventually cleared up when more memory was added to the Portal and hosting servers, but as you can imagine I'm very skeptical that was the issue at hand and nothing more than coincidence.  However it's worth noting just in case something like that may apply to  you...
Craig
