Adding a public Insights model
1410
02-20-2019 06:35 AM
ChaimSchwartz4
Hi - how can I add a publicly shared model? When hitting the "Add to page" button I only see an option of adding a model from my organization...?
ahmed_hussiney
You should follow the following steps in order to see public shared model (which seems to be part of living atlas)
     - In your Insights Page , Press "Add Data"
     - In the "Data" Tab select Living Atlas
     - With the living atlas selected press Model Tab
     - Now you should be able to see public shared Models
Note : the same apply for Themes.
ahmed_hussiney
ChaimSchwartz4
Wow, I would never figured that out - thanks. This doesn't seem to work for me with Enterprise Insights 3.1. installation - but does work with ArcGIS Online.
ahmed_hussiney
Unfortunately ESRI is not supporting this in portal for ArcGIS , it is only for AGOL
