Overlapping Occupant labels in Space Planner
139
10-07-2025 12:20 PM
MollyE
When assigning multiple people to a single unit within the Space Planner app, it will only render a single occupant's name for the label. I'm wondering if there is a way to configure the labels so that they can all show, even if you have to zoom in further to give them all space to render "within" the polygon.
I currently am just manually moving the occupant point in Pro or a web map but I will not be the one responsible for updating occupants once we get the app running and hand it off, and the people who will be responsible for that will not have the capability to do that.
UPDATE:
I did not realize that functionality was within the Space Planner app as well. 😔
AaronKoelker
I think this is more a limitation of the Map Viewer rather than Indoors/Space Planner specifically. All assigned Occupants just become a point at the center of the assigned room in terms of geometry, and the label overlap options are still limited-to-nonexistent in the Map Viewer. I'm not sure of a way you could do this without getting really complicated—maybe creating joined views between Units/Occupants or creating static copies of your Units layer with matching Occupant names all concatenated into a single field. If you were doing this for a custom dashboard or something that might be okay, but with the Space Planner app or Indoors Viewer, that's not going to fly.
-Aaron
