Indoor and outdoor assets
761
06-01-2023 09:33 AM
mshanaghan
New to Indoors -  Within the ArcGIS Indoors data model, is it possible for one feature class to contain features located both inside and outside of a building? For example, could printers (inside) be in the same feature class as vehicles (outside)?
Thank you.
GauravJobanputra
Hello @mshanaghan yes, you can have your data (like fire extinguishers and say, fire hydrants) in the same feature class. Floor-awareness is set on individual layers. You can add your feature class to the map and create a definition query to only show fire extinguishers. Following that, you can set the Floors property to the appropriate column that has floor related values (say, LEVEL_ID). You can add the same feature class to the map again but this time set the definition query to only show fire hydrants. These features would not have any floor related information so no need to set the Floors property.
Hope this helps.
GauravJobanputra
Hope this helps.
mshanaghan
Yes, thank you very much!
AnninaHirschiWyss
Hi @GauravJobanputra would this also work for Events that can take place inside and outside a building/unit?
