Error 000260: The field name defined in attribute rule is not available in class.
2162
08-21-2024 02:49 PM
Chris_Olsen
Pro 3.3.1, Enterprise 11.2
I'm unable to publish my Web Map to Enterprise 11.2 using data coming from my Indoors GDB. 000260: The field name defined in attribute rule is not available in class. I understand this is coming from the attribute rules for one of the FCs, but how can I know where it is? I haven't made any changes to the prebuilt schema deployed by the tool.
I am able to publish the Web Layers as a set, but I need the Web Map due to having Indoor Categories set up on the map.
bbaker_tngeo
I'm having this same issue. I found this article but I am hoping there's been a development since then. https://support.esri.com/en-us/bug/the-package-project-geoprocessing-tool-in-arcgis-pro-fa-bug-00015...
BryndaHatch
Did you create your Indoors Geodatabase on an earlier version of Pro?  Can you try running the Upgrade Indoors Geodatabase tool to get it to the current version of Pro?  After running the GP tool, then try republishing your web map again.
https://pro.arcgis.com/en/pro-app/latest/tool-reference/indoors/upgrade-indoors-database.htm
MatthewStull1
I'm also having this error message but I'm getting it while trying to publish to a mobile map package.  We have recently implemented attribute rules so I'm guessing that this is what is causing the issue.
AaronKoelker
Just want to add that I had the same error trying to import an XML Schema Workspace doc from an Indoors FGDB, and @BryndaHatch 's solution to run the Upgrade Indoors Database tool solved it. Specifically I ran it on the Indoors FGDB, then re-exported the XML Schema file, and then was able to import the xml into another FGDB without error.
-Aaron
