Default filter view in ArcPro/AGO
1227
11-15-2024 11:18 AM
GISMaryWagner
Hello,
We having been slowly but surely trying to implement indoors for our county facilities.  This will include several hundred facilities. I just noticed that by default it seems to always show the Ground (vert order 0) features in the map - both Pro and our published AGO indoor maps.
My questions:
  • How do I override or adjust this default filter setting?
  • Why do the units/details also display by default (I would expect only the "Level" feature class to show)
  • When applying a filter for a different building, the default filter for the ground floor still persists, which does not make sense. Is this expected behavior for the default setting
After a lot of searching I did find this in the documentation.  There has been a lot of hunting for straight forward Indoors documentation....: Visualize floor-aware data using the floor filter—ArcGIS Pro | Documentation assuming that if you don't want the default filter included to turn off the floor filter before publishing?
Lastly, like I mentioned before - this indoors model will include a lot of facilities all with their own set up of floors which has made the level layer a bit complicated.  Is there good documentation or examples for using indoors at this scale?  I feel most documentation is generally focused on one office building rather than a large geographic area (county).
Thanks for any help/suggestions/insight!
Mary
HBWiese
Hi Mary,
I don't have answers to all your questions, but we have an indoor viewer set up with 11 sites and 40 facilities that you can view as an example.  ACC Public Wayfinding Map.
  • When applying a filter for a different building, the default filter for the ground floor still persists, which does not make sense. Is this expected behavior for the default setting - Yes, this is how it is designed.  We would prefer it filter all the floors at the same time.
I hope this is helpful.
--Holly Wiese
GISMaryWagner
Thanks for the response Holly.  I can get past the default ground, but would be nice if once the filter was activated, the entire map was affected.
Mary
SophieFrank
Hi @GISMaryWagner, Wanted to let you know that this is something that is on the product roadmap -- providing options in the floor filter to filter levels across an entire site by vertical order (what I believe you're talking about here), as well as providing an option to only show the floor-aware layers for the facility selected in the floor filter.
