Asset tracking in ArcGIS Indoor Viewer
375
11-30-2023 02:40 AM
AbhyanshuGupta
I have created an Indoor Viewer Application on ArcGIS Indoor Viewer. Now I want to perform Asset Tracking in it. The asset tracking should be so done that suppose if I have an office chair and i want to track it. How can i be able to track it? Do I need to use IPS in my solution or is there any workaround like through the help of ArcGIS Survey123.
Regards
GauravJobanputra
Hello @AbhyanshuGupta for true Asset Tracking, you need to use fix/stick hardware to your assets and use the vendor provided technology to create a feature layer and constantly update location value. You can then add the layer to your indoor map so it available in Indoor Viewer. You will need to research available options. Some examples are Zebra and Fujitsu.
IPS provides a blue-dot on the mobile device to know where you are while using the app which is different from asset tracking.
On the other hand, you can use Survey123 or Field Maps to manually update the location of some assets so they are reflected in Indoor Viewer.
