Update the cache path stored in the mosaic dataset
1743
04-07-2022 10:08 AM
Labels (2)
KeonMonroe
I'm trying to publish an image service drawing w/ pre-built mosaic dataset cache. I am using the tool Build Mosaic Dataset Item Cache (Data Management)
How exactly do you "update the cache path stored in a mosaic dataset"? This is in the last sentence of the Usage section in the documentation, but I can not find this property accessible in the mosaic dataset properties (using the Pro GUI, or as a parameter in the Set Mosaic Dataset properties tool).
DavidPike
MVP Notable Contributor
DavidPike
