I do HAVE a question for you about export my raster from Mosaic Dataset.
How do I permanent set to NONE for Stretch Type in ArcGIS Pro ?
I have Pro as 2.4.3
Don't forget to close the thread Robert
Thanks Dan!
Robert, what Dan described was the app setting, so that no raster layers are ever stretched with a contrast stretch by default - on that particular machine. If that is what you wanted, then Dan nailed it.
If you were only looking to have no contrast stretch on specific raster datasets, you can edit the Dataset Properties (In the Catalog Pane, right-click the dataset in question, and choose Properties). Scroll down to Source Type, and choose Processed. This will now make it so anyone who uses this dataset (regardless of the machine) will see no contrast stretch.
@Simon Woo
Yes I did play it around that part as well... Thank you for the information and that helps to know too.
