Set None as Stetrch Type in Pro ?
3778
6
01-29-2020 10:54 AM
DEAF_PROBERT_68
Honored Contributor
I do HAVE a question for you  about export my raster from Mosaic Dataset.
How do I permanent set to NONE for Stretch Type in ArcGIS Pro ?
I have Pro as 2.4.3
DanPatterson_Retired
DEAF_PROBERT_68
Honored Contributor
Ahhhh.. Bingo !
Don't forget to close the thread Robert
DEAF_PROBERT_68
Honored Contributor
Done. That worked !
SimonWoo
Thanks Dan!
Robert, what Dan described was the app setting, so that no raster layers are ever stretched with a contrast stretch by default - on that particular machine.  If that is what you wanted, then Dan nailed it.
If you were only looking to have no contrast stretch on specific raster datasets, you can edit the Dataset Properties (In the Catalog Pane, right-click the dataset in question, and choose Properties). Scroll down to Source Type, and choose Processed. This will now make it so anyone who uses this dataset (regardless of the machine) will see no contrast stretch.
DEAF_PROBERT_68
Honored Contributor
@Simon Woo
Yes I did play it around that part as well...  Thank you for the information and that helps to know too.
