publishing map service with mosaic dataset fails
3730
06-17-2016 11:11 AM
SebastianRoberts
I have the ArcGIS for server image extension (server and desktop 10.3), and am trying to publish a cached map service using a mosaic dataset. The mosaic dataset references .sid rasters.  When I try to publish the service, I get the error "packaging succeeded, but publishing failed".  My server logs show two related messages:
    1. WARNING: The Layer:'Image' in Map:'Layers' is invalid    Source: System/Publishing Tools.GPServer
    2. SEVERE: Instance of the service 'System/PublishingTools.GPServer' crashed   Source: Same as above
No error report is generated on the server.
Any ideas before I call Esri Support?
DavidHildebrand
I have found out that referenced mosaics can be published as image services but not as map services, at least at 10.3.  I was trying to publish a hillshade map service from a referenced mosaic but I got a similar error to you. I copied my source mosaic to another name and then used the Hillshade function on the copied mosaic.  I was then able to publish a map service.
