Image Service Issues
1506
05-06-2010 01:19 PM
AaronSchuck
I have been having an issue with published image services that I've been creating.  I will go through the process of publishing an image service within an mxd, everything will turn out great, I can host the image on our servers and pull it up no problem.
The thing is, there is a standard deviation stretch applied to the image when I pull up the service in Arcmap.  The problem is fixed easily enough, I just go into the properties of the service, and turn the stretch off.  But I want to know why this stretch applies in the first place...?  There is even a portion within the image service creation wizard that asks if I want to apply a stretch.  I always make sure that this option is left unchecked, yet the stretch comes up in my hosted images every time.  Has anyone else run into this problem?
PeterBecker
The issue is that in one of the processes stats for the service were created and are associated with the service. When ArcMap opens a raster that contains stats it by default applied a 2StdDev stretch. This can be turned off in the ArcMap 'Tools,Option,Raster, Display rasters with contrast stretching' option. This though is only for one machine. There does not exist a specific tool to remove the stats from a service. The simplest method is to open the xxx.ISDef/ImageService.ISDef  file with a text editor. Find and delete the node called <Bands> IE the section
      <Bands>
        <ActualValues>true</ActualValues>
        <Alias>Histogram Generation for ImageService</Alias>
     </Bands>
You will need to recompile the service.
Do not run the Build with the "Compute output properties" else the stats will be regenerated.
AaronSchuck
Hey man, thanks a million!  It worked like a charm!  I really appreciate your help.
