Apply stack process to Landsat imagery
1975
05-05-2010 06:56 PM
Siti_ZalehaMisnan
I have a set of Landsat TM imagery with 7 bands in .tif format. The bands are in separated files accordingly.I've created  image service for this dataset, and now i want to apply stack process to the service. Can anybody suggest me where can I get step-by-step guide for doing this process, I've followed the instruction inside Help..but its confusing.
Please help me..urgent reply needed.
AbhijitDoshi
You need to enable only one tif and disable all other tiff ( by default all are enabled).
Than you can apply the stack band process at the service level and define the number of bands for the output ( should match based on the bands that the service has) Than define the Raster ID for the bands. ( these you can get it from the Attribute table)
this workflow is based on the assumtion that tif files are added as seperate files using the tif raster type.
Regards
Abhijit
Siti_ZalehaMisnan
I have new error: Raster item group with id not found.
I just grab the Raster ID from table, did we need to add additional id to the existed one in raster id column?
AbhijitDoshi
you need to addd .0 after the raster id
Siti_ZalehaMisnan
Thanks for the help, finally it was a success..:p
