Colors not displaying in image service
3503
05-25-2016 08:14 AM
DanielSchatt
hi all, I want to display a set of integer rasters (1 band, 32 bit) in an image service using a color map.  So I added them to a mosaic dataset (also 1 band, 32 bit) and then applied my colormap file to that mosaic dataset using the Colormap function.  The colors display properly in ArcCatalog when I preview the mosaic dataset.
But then I generated an image service from the mosaic dataset and I just see gray in the preview of the image service.  Anybody know what the problem is and what I need to do to make this work?
Thanks!
Dan
PeterBecker
There is a known issue with CLR files with negative values (not being used), but this does not look like the issue you are having. Can you provide some more details on the version of ArcGIS you are using. Also can you provide a sample of the CLR file you are using.
DanielSchatt
Thanks Peter.  Actually, the colors did display properly when I previewed the image service in the Javascript viewer from the REST page.   It also displayed properly when I used it in the sandbox in the Image Service sample .  So this just appears to be an ArcCatalog (and ArcMap) display issue.  I would still like to know  why it's happening as those previews can be useful.   Here's a sample of the color map file, thanks again:
0 204 255 255
1 204 255 255
2 204 255 255
3 204 255 255
4 204 255 255
5 204 255 255
6 204 255 255
7 204 255 255
8 204 255 255
9 204 255 255
10 204 255 255
11 191 239 245
12 191 239 245
13 191 239 245
14 191 239 245
15 191 239 245
16 191 239 245
17 191 239 245
18 191 239 245
19 191 239 245
20 191 239 245
21 178 223 235
22 178 223 235
23 178 223 235
24 178 223 235
25 178 223 235
26 178 223 235
27 178 223 235
28 178 223 235
29 178 223 235
30 178 223 235
PeterBecker
Also check out the following Blog post about Colormaps
Can I create a customized colormap file in ArcGIS? | ArcGIS Blog
