Can Image Server be Viewed in AutoCAD?
1562
08-03-2010 09:26 AM
TonyBianchi
Does anyone out there know if you can connect to an image server in new versions of AutoCAD for aerial viewing in CAD? My current option is Autodesk Map 2008. Thanks in advance.
GrahamW
ESRI Image server for autocad(all versions)
I just found this.. but i'm having issues with autorefresh
MelanieHarlow
The link above will take you to the client for AutoCAD, but this is not compatible with AutoCAD Map. Within AutoCAD Map you may be able to connect to image services serviced as WMS services.
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html?TopicName=What_is_raster_data%3f#/Image...
