ArcEngine Installation error on ArcIMS Server - required for Image Server
2906
04-21-2010 08:25 AM
JoeHershman
I have this issue with Scenegraph.dll installing ArcEngine on an ArcIMS machine. We need to install Engine because we are going to host Image Services.   I get the following error:
'Error 1904. Module D:\Servers\ArcGIS\bin\SceneGraph.dll failed to register...
I found this related solution and did try the manual registration:
http://resources.arcgis.com/content/kbase?q=content/kbase&fa=articleShow&d=33767&print=true
But when I try and manually register I get "Load library(...\SceneGraph.dll) failed. The specified procedure could not be found.
I am installing ArcEngine from the Image Server 9.21 media on an ArcIMS 9.2.0 machine.
-Joe
JoeHershman
So the 'resolution' ended up being to just install the 9.21 upgrade which will run without error.  Not ecstatic about that as a solution, but the best i can get.
-Joe
