Will Deep Learning packages for 3.3 work for 3.3.1 Pro?
1174
01-10-2025 10:54 AM
RoseAmy
Hello,
Silly question but I can't  find the answer.  Will the deep learning packages installed along with AcrGIS Pro 3.3 work if I install patch 1?  I am experiencing a bug that the patch should fix but if the deep learning packages for 3.3 won't work in 3.3.1, then I will have to roll back to 3.0. I noticed on Github that there are ones for 3.0.3 and 3.3 - 3.0.2.
I appreciate your help!
Amy Rose
DanPatterson
MVP Esteemed Contributor
DanPatterson
The installers are by major pro releases, ie 3.2, 3.3, 3.4
Esri/deep-learning-frameworks: Installation support for Deep Learning Frameworks for the ArcGIS Syst...
... sort of retired...
RoseAmy
Thank you!
