Where to download arcgis_learn module?
1226
12-15-2023 12:44 PM
JadedEarth
I'm using deep learning version 3.2.  I'm trying to install arcgis_learn module from Python Command Prompt using:
    conda install -c esri arcgis_learn=2.2.0 python=3.9
But I'm getting this error:  PackagesNotFoundError:  arcgis_learn=2.2.0
Where can I download and install arcgis_learn module?
DanPatterson
Did you install the deep learning framework?
Esri/deep-learning-frameworks: Installation support for Deep Learning Frameworks for the ArcGIS Syst...
learn is in the arcgis module which is probably already installed on your computer in the base or cloned environment
"C:\... your install folder ...\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\learn"
towards the bottom of the page are the downloads by Pro version etc.
... sort of retired...
DanPatterson
