Train deep learning model now running forever
1774
04-05-2024 12:23 AM
EdoardoForzano
Hi everyone, I have been producing some custom deep learning models for object detection. Everything worked and when I was using the "train deep learning model" when running it was showing me the percentage of completion and the different epochs with the average accuracy while running. Now it stopped doing that, no matter the label I prepare and the parameters I use it keeps running forever, without giving me any detail. I tried to use very small amount of data, that according to the past performance should not require much to be processed, but there is no way to make it work. Any suggestion? thanks
DanPatterson
MVP Esteemed Contributor
Tech Support would be your best option,
... sort of retired...
PavanYadav
I understand you're using the Train Deep Learning tool. To see if the tool is functioning properly, check if you're using a CPU or GPU. In some cases, a fairly large amount of GPU memory is required.
To see if your GPU is being used, run the command nvidia-smi -l 5 and monitor GPU usage. Some models, especially those trained with large amounts of data per epoch, can take a long time (e.g., 1+ hours) to train. CPUs are much slower and may not be able to handle memory-intensive training.
nvidia-smi can help you see if your GPU is being used efficiently for the batch size you've set in the tool. For example, if your batch size is set to 4 and only a small portion of your GPU memory is being used, you can increase the batch size.
Pavan Yadav
Product Engineer at Esri
AI for Imagery
Connect with me on LinkedIn!
Contact Esri Support Services
