Train Deep Learning Model, Error: [WinError 5] Access denied
2453
11-11-2024 04:56 AM
rachbauer
Hello 🙂
I tried to train a new deep learning model to classify pixels with forest/trees. However, I got this error message while training, saying that it cannot access a checkpoint:
I used the new ArcGIS Pro 3.4, but I tried on 3.3 aswell and it also did not work.
I trained some deep learning models before on 3.3 and it always worked. Since i didnt really change anything, I am a bit confused why it doesnt work anymore. Please let me know if you know something about this.
Thanks!
rachbauer
I did have it installed yes.
I "solved" the problem with the advanced technique of completly removing ArcGIS Pro and the framework and then installing it again hehe
DanPatterson
did you install the deep learning frameworks for 3.4?
Esri/deep-learning-frameworks: Installation support for Deep Learning Frameworks for the ArcGIS Syst...
... sort of retired...
rachbauer
idanitorres18
I do... and the problem still,  do you have some other solutions?  I've try and anything works 😞
cweirpatrickco
I was getting this same error and tried setting the "Output Folder" param to a local directory (C:\Data\{output_folder}) rather than to a OneDrive directory (C:\Users\{username}\OneDrive\) and the tool ran with no errors... not sure why but just wanted to put it out there as a potential albeit likely temporary solution.
