Problem with Classify Pixel DLPK
2049
08-02-2023 08:48 AM
johnpol
I have a problem using DLPK Super Resolution to apply to a Raster.
ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
Unable to read pixels from the python raster function.
Function Read Error [Raster Function Template]
File "C:\Users\jpolanco\AppData\Local\Temp\ArcGISProTemp11604\super_resolution.dlpk\ArcGISSuperResolution.py", line 168, in updatePixels
xx = self.child_image_classifier.updatePixels(tlc, shape, props, **pixelBlocks).astype(props['pixelType'], copy=False)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\learn\models\_inferencing\_superres.py", line 215, in updatePixels
superres_prediction = util.pixel_classify_superres_image(
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\learn\models\_inferencing\util.py", line 495, in pixel_classify_superres_image
img_normed = norm(tiles.permute(0, 2, 3, 1)).permute(0, 3, 1, 2)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\learn\models\_inferencing\util.py", line 22, in <lambda>
norm = lambda x: (x - mean) / std
ValueError: operands could not be broadcast together with shapes (4,400,400,4) (3,)
Python raster function's .updatePixels() method returned nothing.
Failed to execute (ClassifyPixelsUsingDeepLearning).
2 Solutions
pyadav
@johnpol by any chance your model was trained with 3-band rasters and the above errors was thrown when the model was used against a 4-band raster?
Number of bands (and,  other properties should match e.g. you train a model with 100 cm resolution images, it might not give the best results on 10 cm images).
johnpol
Yes, I found the problem, it was that I used a Raster with 4 bands. I forgot to finish this post, althought thanks for the answer jajaja. Trying to train a model with good results
pyadav
johnpol
AlexaVerónicaGarcíaBarrantes
Hello
So if I trained the model with a 3- band raster I won't be able to use it to detect with a 4 band raster? why is that?
fenglinhan1
I am a newby of arcgis pro. can some one give me a toturial on how to prepare data for this dlpk model?
Use the model—ArcGIS pretrained models | Documentation
i want to try this.
