Pre-trained deep learning model for vineyards?
934
10-08-2025 04:05 PM
JimWooten
Does ESRI have a pre-trained deep learning model for vineyards? Alternatively, will text SAM be able to detect vineyards? Thanks for any help.
Jim
BobBooth1
I don't see one that is trained to detect vineyards.
You might give this one a try:
https://www.arcgis.com/home/item.html?id=eb5f896bf88b46af8252e17fa404a73d
Also, as you mentioned, TextSAM may work.
JimWooten
There's also the Prompt based segmentation model.  From the description: Visual prompting could be helpful, where it is hard to describe an image through text prompt due to the complex features in the image, by directly providing the image as prompt for generating the segmentation mask."
