Detect Objects Using Deep Learning Error 160105
1555
06-23-2021 09:19 AM
HKrell
Hi everyone,
I'm a newbie to deep learning, and I'm trying to run the Detect Objects Using Deep Learning tool in the Deep Learning toolkit in ArcGIS Pro 2.7. The tool ran for about 2 and a half hours before returning error 160105: Connection to Esri OLE DB provider is invalid. I ran the tool again to have it fail in 27 seconds. Please look at the attached file with the parameters and the error message. I just used the default environment parameters. Please help if you can, I'm stumped.
AmlanR
by Esri Alum
Esri Alum
Hii @HKrell  I am not sure I can access any screenshots you were trying to share.
I was curious to know where the data is located.
Is the raster you are trying to inference on located in a SQL server/ Oracle/ Postgres/ by any chance?
If yes, could you trying putting the raster on a local drive and trying again?
What about the model?
