how to create a raster layer from netcdf file having multiple variable with multiple dimensions
2974
05-06-2021 02:04 AM
Labels (2)
RehanChaudhary
i have a single netcdf file  which has 3 variables named temperature,salinity and pressure and each of these variable have 3 dimensions which are lat,long and time. I want to display this file as a raster layer  in ArcGIS Pro 2.7.3 but when i simply import it using multidimensional raster layer and using any of the output configurations, it displays nothing. How can i display it properly so i can publish it as a service(which i know already)?
P.s i am able to display files having a single variable
DanPatterson
MVP Esteemed Contributor
is it in a convention supported by esri?
Fundamentals of netCDF data storage—ArcGIS Pro | Documentation
... sort of retired...
RehanChaudhary
https://file.io/OQsgykGWczpu
Here is the file with which i am trying. As far as i understand its following the conventions but please let me know if there is any problem with it
DanPatterson
Sorry.... it was a busy gardening day.
I will move it to another Community space where netcdf is used to see if anyone there can follow up
RehanChaudhary
could you please tell me where you moved the question or if you found a solution for this?
