Detect Object using Deep Learning (image analyst tools)
1096
11-29-2023 07:24 PM
vinhle2
I encountered the below problem when trying to do run detect objects using deep learning
The model I use is at:
https://www.arcgis.com/home/item.html?id=2fd653cd9de446ccbab34f69e9e70d81
ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
Thanks for any help.
PavanYadav
@vinhle2 Are you able to use the Detect Objects Using Deep Learning tool with any other models on the same machine?
Pavan Yadav
Product Engineer at Esri
AI for Imagery
Connect with me on LinkedIn!
Contact Esri Support Services
PavanYadav
BTW, I have been able to use the model with a few different examples images; that's why I wondered the problem you faced may not be specific to the model.
Pavan Yadav
AI for Imagery
