ArcGIS Pro Deep Learning v3.2 still not using multiple GPUs
3008
6
11-28-2023 08:14 AM
JadedEarth
I'm using ArcGIS Pro and Deep Learning API v.3.2.  My machine has multiple NVIDIA GPUs:  4 RTX A4000 and 2 RTX A6000.  In addition, my machine also has the Microsoft Basic Display Adapter and Microsoft Remote Display Adapter, 28 cores, 1 TB of RAM and running Microsoft Windows 10 Enterprise.
According to here, if I use model parameter U-net, ArcGIS will use all available GPUs.  I selected GPU as my processor type and left GPU ID as blank, hoping it would use all available GPUs.
However, based on Task Manager display, the CPU is doing most of the work.  CPU_trainModel.JPG
I also tried nvidia-smi to check the performance and it's also showing that the GPUs are practically not being used.
The following shows my parameter and environment settings:
What am I doing wrong?  Appreciate any help.
DanPatterson
MVP Esteemed Contributor
@PavanYadav based on your multiple responses to previous questions by @JadedEarth could you report on the assertion that multiple/all GPUs will be used if available.
Perhaps a more directed case list of configurations in the documentation is needed, although I find the existing documents clear, except on this GPU point.
... sort of retired...
PavanYadav
Hi @DanPatterson
Currently, the Train Deep Learning tool supports multiple GPUs for the following model types:
  • ConnectNet
  • Feature classifier
  • MaskRCNN
  • Multi Task Road Extractor
  • Single Shot Detector
  • U-Net
We are currently working on supporting multiple GPUs for inferencing.
thanks
Pavan
Pavan Yadav
Product Engineer at Esri
AI for Imagery
Connect with me on LinkedIn!
Contact Esri Support Services
DanPatterson
See the first post. The user is using U-Net for training
JadedEarth
The computer we're using is NOT a desktop computer since we needed to install multiple GPUs.  Here's the computer photo below.  We also added multiple GPUs on this computer.
JadedEarth
Now, I'm told multi-gpu support only works from command line.  Does anyone know where the instructions are located for command line deep learning instructions for multi-gpu?
PavanYadav
@JadedEarth The Train Deep Learning tool of ArcGIS support multiple GPUs. for select model types. We are hoping to have all inferencing support it in 3.3 release. And, yes the API has more support training.
https://developers.arcgis.com/python/guide/utilize-multiple-gpus-to-train-model/
https://pro.arcgis.com/en/pro-app/latest/tool-reference/image-analyst/train-deep-learning-model.htm
Pavan Yadav
AI for Imagery
