Invalid JSON Data
1285
06-28-2021 02:53 AM
HamzaM
I am following this course https://www.esri.com/training/Engine/defaultui/player/modern.html?configuration=ReturnUrl%7C&prevent... on esri academy in the Data Engineering section at the last part time stamped 12:46  which is to convert the data to a spatial feature class to be able to visualize it on the map on arcgis pro i get this error.
HamzaM
@Anonymous User @KlaraSchmitt @BrianRollison @JustinPrather @ThomasHervey1
Can anyone help solve this issue.
ThomasHervey1
Esri Alum
@HamzaM
It looks like your question relates to ArcGIS Pro, not ArcGIS Hub. I suggest that you look through the existing questions under the ArcGIS Pro product discussion and pose your question there if you don't find an answer.
